2 Pages<12
#11 Posted : Wednesday, June 29, 2011 9:16:54 AM(UTC)
Process of elimination works
Or
You can force a heating cycle (see the tech sheet) and measure to see if the board is supplying power to the heater/thermostat combo.
rtf505
#12 Posted : Sunday, July 3, 2011 3:49:04 PM(UTC)
rtf505
Okay, replaced the control board and the washer lit up, but no sound of water running as was usual. After about 2-3 minutes it started running cycle, still without the water sounds. It ran a full cycle on pots and pans with the "sanitize" led on. High heat dry worked and hot moist air could be felt through the vent. Upon completion of cycle only the "clean" light was lit. Upon opening the dishwasher the bottom of the tub still contains 1-2 inches of water. Removed dishes and ran another cycle with same result.
Wife is talking about getting a new dishwasher or home handy man. . . Suggestions???:confused:
#13 Posted : Tuesday, July 5, 2011 12:15:49 AM(UTC)
Check that the overflow switch is activated.
Sometimes the float can get stuck in the up position.
rtf505
#14 Posted : Tuesday, July 5, 2011 6:13:38 AM(UTC)
rtf505
Yea, well it also drains better if you knock the plug out of the new sink disposal unit you just installed too. Ran another cycle and the heat dry seemed to work, but still no sanitize light at the end of it.
Guest
#15 Posted : Monday, December 4, 2023 4:37:47 AM(UTC)
Guest
Rank: Guest
United States
I have a Bosch dishwasher and I can’t get the sanitizer light to come on. Does that mean it will not sanitize my dishes
Guest (5)
2 Pages<12
