Neither oven nor broiler working althought seperate systems and igniters. Burners work fine. Igniters not glowing. Looked under cover and found two micro switches. One for self clean and I guess the others are for broiler and oven. Watched as I turned the control knob, nothing. Any thoughts
RLC
Possible there is a wrong clock settings.
If you can post a pictures of the control panel and the clock, it might help to diagnose the problem.
Thanks Gene, I checked the clock panel once before but must have missed something. Started from scratch and now I have my "oven" back.
Thanks much, Richie Conrad
You are welcome. I'm glad you were able to fix it.
