wally_games
#1 Posted : Saturday, July 2, 2011 10:50:03 AM(UTC)
wally_games
The compressor fan motor started getting louder, like a vibration sound, and is getting worse. Now it's like the blade is touching something and is VERY loud. At first I thought it was the compressor, but the fan motor vibrates when I touch it.
I've found the fan motor on the website and it's almost $100. I don't mind paying that for it, but I want to know how hard it is to replace. It's hard to reach under the door and I suspect that I'll have to tilt it back.
Any insights or suggestions?
#2 Posted : Saturday, July 2, 2011 5:35:26 PM(UTC)
Check the fan blade for unbalance and also see if the screws are loose causing the problem.
If the motor bearings are bad, I would use a SM999 motor, less than half price and more reliable.
wally_games
#3 Posted : Saturday, July 2, 2011 5:43:46 PM(UTC)
wally_games
With where is is, how do I get to it to replace it? Do I have to tilt the whole thing back to get underneath?
#4 Posted : Sunday, July 3, 2011 1:09:27 AM(UTC)
You will need to remove the freezer back panel.
Guest (4)
