zaxxon
#1 Posted : Sunday, September 14, 2008 8:15:08 AM(UTC)
zaxxon
hi, i am replacing the seal and tub bearing. the metal sleeve on the shaft is stuck and will not budge. any suggestions on how to remove it would be much appreciated.
lex
#2 Posted : Tuesday, December 2, 2008 7:13:25 PM(UTC)
lex
I am having the same problem with trying to get the metal collar sleeve off also. I have a maytag washer lat 9416aae. Were you able to get it off? If so, I would appreciate any help to get mine off. I was just wondering what symptoms your machine was having for you to determine that it was the mounting stem seal and tub bearing? My washer does not spin, but does everything else. So, I am guessing its the seals and bearing.
fixtec90
#3 Posted : Wednesday, December 3, 2008 4:23:11 AM(UTC)
fixtec90
That sleeve is a soft metal and can be chistled (spelling?) off. Be careful not to damage the tranny shaft.
