Dishwasher is pumping small amounts of water out during wah cycle. Diswasher will pump out all water during wash and then it will not hsve any left to wash dishes. Dishwasher will pump out water when it calls for pump out.
Groups: Joined: 12/1/2008(UTC) Posts: 0
I would go directly to the drain line on this unit. It sounds like it has no siphon break. Most dishwashers drain into the sink drain, using the sink itself as a siphon break. If the drain goes directly into a drain line without the benefit of a way to get a "breath", the water will siphon out, leaving no water in the unit to circulate. If the unit cannot be drained into the sink drain, you will most likely have to add an aftermarket siphon break to prevent the siphoning effect. I hope you find this helpful!
Found out by using cheap store brand liquid dish washer soap, caused the fine filter to plug up causing the water to be pushed out the drain.
