Abiabi
#1 Posted : Wednesday, December 3, 2008 2:12:51 AM(UTC)
Abiabi
The problem: little water gets in. It hardly covers the bottom filter.
Water does not go through the spinning arms. (last week it did, but without enough pressure)
I flipped the Dishwasher, and tubes seem to be clean.
We have always used the dishwasher with semi clean plates.
All visible filters o of easy access are clean. Tubes are clean.
I have been told that a possible problem is the electric "presostato"that controls the engine and thus the water lever.
Is this true?
Which is the part at the bottom of the Dishwasher?
Any suggestion?
Do you have the assembly part for this dishwasher?
#2 Posted : Wednesday, December 3, 2008 2:27:02 AM(UTC)
Check for a clogged screen in the water solenoid.
Abiabi
#3 Posted : Wednesday, December 3, 2008 4:00:12 AM(UTC)
Abiabi
Could not understand what you mean
#4 Posted : Wednesday, December 3, 2008 5:20:25 AM(UTC)
Pull out the water solenoid under the dishwasher and clean the internal screen
If ok, replace it with a new one.
Abiabi
#5 Posted : Wednesday, December 3, 2008 6:24:43 AM(UTC)
Abiabi
The water solenoid, that is at the the external water intake was clean.(I opened it)
From the solenoid a thick tube goes into an hermetic plastic basket. The basket seems to be infernally divided in 2. On the side where the tube goes in, an where another tube leaves for the pump, there is an organ jelly substance, on the other side the water is Cristal clear. Should I clean this orange substance?
#6 Posted : Wednesday, December 3, 2008 7:02:20 AM(UTC)
This orange stuff might be soap residue. You can dissolve it with vinegar.
Abiabi
#7 Posted : Monday, December 20, 2010 4:28:36 AM(UTC)
Abiabi
I'm sorry for not answering to u before. The problem has been the pump. I was blocked. With son W-40 it worked.
Today Dec 20, the problem came back. This time the pump is completely blocked (even with w-40). I am apfraid that I will have to change the plastic turbine.
Do you know an estimated price for it?
