promopunk
#1 Posted : Monday, December 1, 2008 8:10:52 PM(UTC)
promopunk
in trying to repair a completely unrelated washer issue with my ge spacemaker unified laundry machine(s), i saw what appeared to be a large collection of lint where the air duct meets the front blower housing. upon further inspection, it appear that this was, in fact, a foam gasket between the 2 parts that was in less than stellar shape, allowing for lint to fall into the inside of the machine. i have 3 questions regarding this: 1. is this in fact a gasket? 2. if so, can it be replaced without having to purchase a new air duct or front blower housing (i cannot find any sort of gaskets on any site)? 3. if it cannot be purchased separately, is there an adequate substitution that i can make? thank you very much in advance for your help.
libertyappl
#2 Posted : Tuesday, December 2, 2008 8:41:06 AM(UTC)
libertyappl
Yes there are "gaskets" around the drum, Glide drum <upper and Part Details - GE Lower felt, part number: WE9X105 < lower seal
Here's the breakdown Model WSM2780WAWWW, these are #1220 & 1221 on the drum page.
Nat
promopunk
#3 Posted : Tuesday, December 2, 2008 10:33:55 AM(UTC)
promopunk
Nat
sorry if i wasn't clear (i am a newbie at appliance repair)...using the same breakdown, i am wondering if there is a sort of gasket that goes where parts #1306 and #1310 meet. the gasket by the drum is still in good shape. thank you again!
#4 Posted : Wednesday, December 3, 2008 1:26:46 AM(UTC)
Looks like they have redesigned this area of your unit.
There is a good chance this was done because the foam seals were deteriorating.
Any ways I may have found you an alternate
Model GEQ8821LL0
Take a look in Section 3 Items 60 and 62.
Am not sure if the above will be long enough but they seem to do the same job.
Another possibility is to get some peel and stick door/windows weather stripping. Try to find the one that is a heavier type of foam material.
A better solution would be to use duct sealing tape not the fiber type but the stuff heating contractors use which will take higher heat. It is hard to see if there is a lip on Part 1310 to tape to so this may not work.
