2 Pages12>
rboyd
#1 Posted : Friday, October 26, 2007 8:43:38 AM(UTC)
rboyd
Older Maytag washer leaks from the left side while the water is filling the tank. Are there any hoses going to the top of the tank and how do you open the washer to check for loose hoses?
#2 Posted : Friday, October 26, 2007 8:57:07 AM(UTC)
Hi rboyd
In order to provide the most accurate advise I need the complete model number of your washer. You can find it on top of the control panel.
wonderwomanbee@msn.com
#3 Posted : Friday, November 9, 2007 3:54:09 PM(UTC)
MODEL LAT9593AAL
Facing the washer, the small leak is coming from right front corner. I had a GE washer that did this once. However, it was a large leak. The repair said it was off balance. He adjusted the legs and it work ok. Could this be the same case. Do I just maybe need to adjust the legs/or tub could be off balance?
Wonderwomanbee
#4 Posted : Friday, November 9, 2007 5:24:46 PM(UTC)
Hi Wonderwomanbee
Remove the front panel and you will see exactly where the water coming from. Then replace the leaking part and enjoy.
- Here are the break down diagrams for the Maytag washer Model LAT9593AAL
Good luck.
#5 Posted : Friday, November 9, 2007 7:39:21 PM(UTC)
Gene,
Thanks for your help. I took the front panel off and the leak is at the base of the tub. So it looks like, I would need a mounting stem & boot seal. I was hoping to repair it myself. It looks like some work to take it apart. I am not sure where to start.
Is it easy to replace or with no experience would it be wiser for me to call a repair man. I also see the part is not cheap. Give me some feedback.
Thanks, Wonderwomanbee
#6 Posted : Sunday, November 11, 2007 1:12:06 PM(UTC)
Hi Wonderwomanbee
Yes, you were right.
In such situation the mounting stem and boot seal has to be replaced.
I can not say this is a very simple job, but with a basic knowledge how to use a hand tools you can do it.
You have to have:
1. The spanner wrench - part number AP3538707
2. A set of socket wrenches
3. A set of hex keys
4. A 1/4' nut driver
5. A hummer
You can find the complete instructions how to replace the mounting stem and boot seal on page 3-35 in the service manual.
Good luck.
vole
#7 Posted : Friday, January 23, 2009 9:51:39 AM(UTC)
vole
I've read this thread after finding water by my Maytag washer. I took of the front panel, filled it with water and ran a cycle but don't see anything leaking or anything wet.
Looks like it must be coming from under the bottom floor panel. I tipped the washer over but nothing obvious. I can't fill the washer and run it tipped over to look for the leak.
Any suggestion where the leak is coming from and what to do?
Thanks for any help.
-Dave
Affordable Alternative Dental Insurance - Employee Dental Vision Health Benefits for Small Businesses
magician59
#8 Posted : Friday, January 23, 2009 11:06:35 AM(UTC)
magician59
Dave, Your leak is most likely to be at the injector valve. This is an aerator system that is located at the top left side of the tub. Water splashes out of the plastic housing as the washer fills. All that normally needs to be replaced is the injector valve and sleeve. Two parts that may set you back around $20.
vole
#9 Posted : Saturday, January 24, 2009 2:37:07 PM(UTC)
vole
I'll remove the top and look for it tomorrow. It's -5 degrees tonight and even though I'm indoors my fingers feel numb.
Thanks for the help.
-Dave
radarraden
#10 Posted : Monday, February 9, 2009 8:15:44 AM(UTC)
radarraden
Hi, Hey I was having the leaking problem with my Maytag LA512 Washing Machine and replaced the injector valve, however the leak/overflow keeps happening randomly - can you suggest another solution?
Thanks. Debbie
Guest (6)
Which part should I replace for leaking Maytag washer (Washer Repair)
by allofakind 3/5/2015 6:17:16 AM(UTC)
Water Leaking Maytag Washer Below the tub (Washer Repair)
by bhasho 4/19/2012 2:43:29 PM(UTC)
leaking maytag washer (Washer Repair)
by pageroc 1/13/2009 12:34:17 PM(UTC)
2 Pages12>
