jimfromtexas99
#1 Posted : Friday, July 1, 2011 10:38:27 AM(UTC)
jimfromtexas99
I recieved a replacement condenser motor, and the instructions to change the wiring do not match what I have or what I was sent. the original motor had 4 wires, 2 white and 2 red, in a connector, with the same color wires hooked together, and 2 terminals on the motor. The new motor has 3 terminals, and the new connector has 3 wires, 1 white, 1 red and 1 green. I would assume the red and white wires from the old connector would hook to the red and white wires from the new connector, but where do I hook the green wire from the new connector.
Joe / APP Team
#2 Posted : Friday, July 1, 2011 11:21:13 AM(UTC)
Joe / APP Team
Jim,
Did you order part number :
Part number: AP3108246
Was instruction sheet number 4387245 Rev. D 7/05
(refer to application 2 or 3 of the instruction sheet
included in the packaging ?
The green wire in the "new" wire harness, in the kit, should be attached to the either green or green/yellow wire and wire nutted so there's no possible short circuit.
You'll be fine either way.
Good Luck,
jimfromtexas99
#3 Posted : Friday, July 1, 2011 12:57:35 PM(UTC)
jimfromtexas99
thank you Joe, that worked, though instead of hooking it into an existing wire, I put a terminal on it and used one of the mounting screws to attach it to the frame, and the green/yellow wires were attached to the frame too, so that completed the ground circuit, everything is running fine, so again, thank you for your assistance
Jim
Joe / APP Team
#4 Posted : Friday, July 1, 2011 1:46:21 PM(UTC)
Joe / APP Team
Jim
Jim,
It's our pleasure to assist.
I had a feeling you'd figure it out, and be up and running.
Thanks, and Good Luck,
:D :D :D
