dlchunting
#1 Posted : 16 years ago
dlchunting
Whirlpool oven (mod RBS275PDQ16) won't heat up at all. Took thermostat off and straight wired it and it still won't heat up. Any suggestions? Thanks
kayakcrzy
#2 Posted : 16 years ago
kayakcrzy
If you are talking about the thermostat in the back of the oven, that you had to remove the oven, and take the back panel off to get to, and you jumped it out and the oven won't come on. Provided you have full power, you would need a clock control board. Tom ApplianceEducator.com
dlchunting
#3 Posted : 16 years ago
dlchunting
How can I tell if the thermostat is the problem?
kayakcrzy
#4 Posted : 16 years ago
kayakcrzy
If you take the 2 wires off, and put them together. Of course you have the power off when you take the stove out, and put the terminal ends together, and put some tape around it so it does not hit metal, and then turn the power on. If it comes on, replace it. I also must ask if this problem occured after you put the oven in a clean cycle. Tom ApplianceEducator.com
kayakcrzy
#5 Posted : 16 years ago
kayakcrzy
UserPostedImage
The part # that I am talking about is #37. Tom ApplianceEducator.com
dlchunting
#6 Posted : 16 years ago
dlchunting
Okay thank you. The thermostat is good then. I think its two relays on the control board.
whirlpool oven won't heat up (Oven Repair (including Ranges and Cooktops))
by smeighan 12 years ago
Whirlpool Oven won't heat up (Oven Repair (including Ranges and Cooktops))
by jims 16 years ago
