dadunn60
#1 Posted : Tuesday, December 2, 2008 5:34:06 AM(UTC)
dadunn60
I have a small apartment size refrigerator/freezer and the refrigerator side will not get cold. I have noticed Ice forming in the top of the freezer section too. This problem occurred sometime back and I up plugged the unit for about two weeks and when I plugged it back in it worked fine until now. Any suggestions would be of help.
libertyappl
#2 Posted : Tuesday, December 2, 2008 8:30:54 AM(UTC)
libertyappl
When it freezes up either unplug it with the door open for a day or so or use a hair dryer to defrost it as needed. There aren't many parts available for those units.
Nat
dadunn60
#3 Posted : Tuesday, December 2, 2008 1:27:14 PM(UTC)
dadunn60
Does the build up of ice have anything to do with the refrigerator part not cooling properly?
libertyappl
#4 Posted : Tuesday, December 2, 2008 2:18:03 PM(UTC)
libertyappl
Yes it blocks the air flow into the refrigerator part.
Nat
dadunn60
#5 Posted : Friday, December 5, 2008 4:58:43 PM(UTC)
dadunn60
The Ice build up is at the front on the top next to the door. I was thinking the defrost cycle is not working?
libertyappl
#6 Posted : Saturday, December 6, 2008 6:59:47 AM(UTC)
libertyappl
If it's near the front, check the door seal make sure it is tight all the way around, a dollar bill works good for checking this.
Nat
Guest (5)
