ou812cw
#1 Posted : Tuesday, June 28, 2011 6:00:27 AM(UTC)
ou812cw
My washer decided to quit agitating and spinning motor tirns freely any ideas????
jdgriffith
#2 Posted : Tuesday, June 28, 2011 4:03:47 PM(UTC)
jdgriffith
Check behind the front kick plate...I found an envelope with all the info needed to test, find an error code, and replaced the door lock assembly...It worked
Frigidaire Gallery Washer Leaks at Bottom (Washer Repair)
by calvin83 2/5/2014 3:44:39 PM(UTC)
Frigidaire Gallery washer (Washer Repair)
by mwilliaims 1/31/2013 9:57:03 AM(UTC)
Frigidaire Gallery Washer not agitating (Washer Repair)
by ckilly 12/23/2011 6:43:51 PM(UTC)
Frigidaire Gallery Washer leaves dark spots on clothes (Washer Repair)
by kharston 8/12/2011 12:08:47 PM(UTC)
Frigidaire Gallery Washer Beeping (Washer Repair)
by aholcombe 4/7/2011 1:57:57 PM(UTC)
frigidaire gallery washer problem (Washer Repair)
by one2many 8/12/2009 12:15:25 PM(UTC)
Frigidaire gallery washer (Washer Repair)
by jellyb 5/4/2009 7:52:24 AM(UTC)
