chanchar
#1 Posted : Saturday, June 25, 2011 11:11:44 AM(UTC)
chanchar
Hello everyone,
I recently got numerous messages from my washer telling me "3E" and it keeps on ringing and ringing. I just ordered the motor from appliancepartspro and installed it. However, I still get the error. 3E comes when the washer fills up with water and then stops before spinning. Other times it will spin for a couple of cycles and then suddenly 3E would pop up which cancels the entire wash. What could be wrong with the washer? What makes 3E pop up? Could it be the speed sensor, motherboard, etc.? Please responded as soon as possible.
Thanks,
Charles Chan
sidfink43
#2 Posted : Monday, June 27, 2011 5:02:37 PM(UTC)
sidfink43
That error codes means the main control doesn't think the motor is working, so it shuts things down.
I would try replacing the main control. If that fixes things try putting your old motor back in. APP will take back parts that do not fix the machine, see the returns policy for details and conditions.
