andrewtac
#1 Posted : Sunday, June 26, 2011 12:59:45 PM(UTC)
andrewtac
the error code had 6 beeps/flashes. runs sometimes correctly, but when used several times in a row won't complete cycles. Acts like it did when the pump failed last time. Replaced the pump, and it still doesn't drain. I know the pump is good, because it drains some times. Also, the one I took out seemed good too. I am thinking about pulling the board to see if there are any loose solder joints, I did that one my range and fixed the oven.
Andrew
zcimba
#2 Posted : Monday, June 27, 2011 1:17:03 PM(UTC)
zcimba
remove pump and boot from pump to tub. there is a filter inside which is most likely filled. if not check for leak from top fill boot onto motor control,or just bad motor control.
andrewtac
#3 Posted : Monday, June 27, 2011 1:45:32 PM(UTC)
andrewtac
I cleaned the boot and filter when I replaced the pump (it had a dime in it). Where do I leak check, there is no water coming from the boot, or anywhere for that matter? And where is the motor control, is it the "board"?
