lagerman1
#1 Posted : Thursday, October 25, 2007 9:06:46 AM(UTC)
lagerman1
Dryer turns on as soon as you turn the timer/temp selector.You don't have to push the start button anymore.It stops and the end of the cycle but the timer keeps running, so it starts up as soon as it gets in a new cycle.
#2 Posted : Friday, October 26, 2007 3:24:14 AM(UTC)
Seems like shorted contacts in the timer plus a shorted start switch. Pull out timer and take cover off to verify.
#3 Posted : Friday, October 26, 2007 12:23:44 PM(UTC)
The first thing I would check is the start switch.
#4 Posted : Friday, October 26, 2007 1:44:02 PM(UTC)
If the start switch was the only problem, it would not run in the timer off position.
