I have a front loading kenmore about 4 1/2 years old and the inner drum appears to have fallen off of its mounting bolt/bracket/whatever. It just started banging around when it hit the spin cycle and I can see when I open the door that the inner drum has dropped by about 2 inches. Is the something a DIY'er can repair or am I stuck paying sears 70 bucks just to come look at it and to charge me who knows what to repair it? I took off both the front and back access panels and everything looks good and there are no loose screws or bolts or anything so it has to be inside the inner drum where the connection came loose. Any help would be greatly appreciated.
If this is a regular dryer, the rollers and the idler pully, and the belt, all come in a kit. You have to take the drum out, and that is where everything is. Sears, what a rip!!! Tom ApplianceEducator.com
Sorry, I should have specified that this is a front load washer. my bad.
Sorry, I would not know what the problem is. I would repost it, with the model #. Tom ApplianceEducator.com
