Got error code F7. I turned power off then back on at the breaker and it reset and worked for a while (days). Did this successfully for the last month, but it's all dead now. Appreciate the help.
Lane
9 times out of 10, the control panel needs to be replaced to fix the F7 problem....Here is that part---> AP3185757. You can do a quick test to see if it is the panel, or the erc control.... Take the control panel off....3 screws under the panel, push up and off, make sure power is off. now disconnect the ribbon cable and reapply power, if you get an F7 within about 3 minutes, the erc control needs to be replaced, if F7 does not come back the panel needs replacing.
Quote:if F7 does not come back the panel needs replacing. Just as you said!! Part on order. Thank you very much for the help, it is GREATLY appreciated!! Lane Update: Part arrived, took 5 minutes to install, and oven works. Thanks again.
