artsolisjr
#1 Posted : Monday, December 1, 2008 9:48:12 AM(UTC)
artsolisjr
My agitator does not work, it will remove the water ans spin it just won't agitate.
#2 Posted : Tuesday, December 2, 2008 1:17:56 PM(UTC)
Remove the agitator and check the drive block (#38 on the break down diagram). If this part is worn out then it has to be replaced.
Unfortunately this part is no longer available.
Here are the break down diagrams for the Norge washer Model LWL203W
Agitator problems (Washer Repair)
by pinkcuda 1/25/2014 12:51:15 PM(UTC)
agitator problems (Washer Repair)
by rusdkin 1/6/2013 11:30:47 AM(UTC)
Centennial Agitator Problems (Washer Repair)
by Dgrega 10/10/2011 7:52:43 AM(UTC)
