we are a garden apartment complex in westchester county. this is the 3rd stove maytag that needs a circut board ???? the serial number is 12432479JZ i found the part number on your site # AP4101 which i think is the proper part number. however I would like to ask you if we can just purchase the circut board without purchase the set which includes the face of the board.???? When the board breaks this particular time is said A5 usually it just does not work at all with the other ones that this happened too. I noticed in the brochure that it indicated something about a Sabbath Mode??? which does not have no beeps and no display. can this be the possible problem?? then you have to cancel, press and hold the clock pad for five seconds.
If the oven is in Sabbath mode then "SAb" will displayed. You have to press and hold the "Clock" pad for 5 seconds to turn it off. You said it shows "A5"? This not a valid error code. Can you be more specific on the problem? So far I did not understand why do you have to replace the control board. The new clock comes with the overlay from the manufacturer. Here are the break down diagrams for the Maytag range Model MGR4451BDWGene.
