dk60089
#1 Posted : Friday, June 24, 2011 9:26:48 AM(UTC)
dk60089
The refridgerator will not cool below 42 Degrees. I have looked at the evaporator and there is no frost build up. I have replaced the thermostat to no avail. The compressor runs and the evaporator fan works fine. Could this be a defrost timer issue? Any help will be appreciated. Thanks.
dk60089
#2 Posted : Friday, June 24, 2011 2:19:51 PM(UTC)
dk60089
I replaced the defrost timer today and the fridge cooled to 34F for a while but then went up to 50F again. Still sitting in the mid to high 40s range for a couple of hours.
#3 Posted : Saturday, June 25, 2011 1:56:42 AM(UTC)
You have refrigeration problems for a pro to look at. Either that, or your compressor start device is failing.
dk60089
#4 Posted : Saturday, June 25, 2011 4:23:09 AM(UTC)
dk60089
Thanks. If it is the compressor start device would that be part AP2992825 ?
#5 Posted : Saturday, June 25, 2011 5:16:16 AM(UTC)
Pull the back off the fridg and check the compressor. If running and the condenser is warm but not hot, you most probably have a refrigerant leak and/or a bad compressor. Sometimes the compressor will shut down on thermal overload, but probably doesn't apply in your case. Only amprobe and gauges would confirm bad compressor.
