My Jenn-Air Microwave will not heat. Could it be a thermostat? Everything else works on it. It acts like it is working but the food is cold. Model# JMV8196AAB.
If the interior lights and the turn table are working and there is no unusual noises then, most likely, the problem is a bad magnetron or a bad control board. - Here are the break down diagrams for the Jenn Air microwave Model JMV8196AABGene.
