ge9172
#1 Posted : Saturday, November 29, 2008 6:37:38 PM(UTC)
ge9172
My microwave appears to be working. The table turns, the light is on, it makes noise, but no heat is being generated. Is this easy to fix? It is a 2006, is it under warranty?
#2 Posted : Sunday, November 30, 2008 6:10:25 PM(UTC)
Hard to say if it is an easy fix.
Here is the tech sheet
https://www.servicematters.com/d...0Sheet%20-%208205609.pdf
You say it makes noise but can you hear the magnetron turning on/off at a 50% heat setting? Usually is a slight buzz (not loud) or the unit sounds like it is bearing down. If yes then your magnetron is probably shot.
Could be one of the thermostats/cutoffs is open.
Remove the wire from one side of each of them and check them for continuity with a meter.
Looked up your unit on the Whirlpool website, says it only has one year warranty.
