Installing the designated model. I am told water does not feed to icemaker. All else is operable. I suspect "valve, solenoid" part # 2002182. How may I service or test this part ? Thank you, Kevin blueye1965@aol.com
Originally Posted by: blueye1965 Installing the designated model. I am told water does not feed to icemaker. All else is operable. I suspect "valve, solenoid" part # 2002182. How may I service or test this part ? Thank you, Kevin blueye1965@aol.com I believe your group had replied with the part number which was superceded. Please let me know which part I shall now order and I'll put the order thru your firm Thanks Kevin Blueye1965@aol.com
