my 50 gallon water heater stopped working,i replaced the thermal coupling but pilot is still not turning on. what could be the problem? gas supply is good.
A make and model number would sure help. :)
the water heater is GE and the model number is GG30T6XA, and is a 30 gallon tank,not a 50 gallon.
Originally Posted by: wecaonimabb789  :mad: What happened ? mommy left you by yourself so you can post this garbage.
thank you icehouse i will look it up.
Originally Posted by: dfedgn24865  Must be visiting hours at the nuthouse.
