After the cycle starts the washer fills up with water, then when the wash motor kicks on it makes a god awful noise. Sounds like bearings crunching and a surging motor. See the clip below, the mayhem starts at 13 seconds after it fills. YouTube - ‪Maytag "Quietseries" 200 dishwasher making noise‬‏You think this is just the wash motor? What parts do I need? Thanks. If it's the wash motor, that part is like 200 bucks, so is it worth risking trying to fix it when it won't fix it?
Fixed it myself. Bits of broken plastic were in the chopper getting jammed
