brbartsc
#1 Posted : Wednesday, November 26, 2008 2:17:52 PM(UTC)
brbartsc
My belt drive Whirlpool washer will not spin. The motor makes a sound like it is spinning, but it is not. It did spin when it was empty as I was draining it before taking the drum out. I took out the drum and checked for stuck socks and tightened the belt. Most of the time the drum feels locked up when I try to turn it by hand. It seems to agitate and pump just fine. My research all points to a motor coupler, but I think that applies to the direct drive models. Can you give me some clues as to the cause of this in a belt drive model. Thanks.
#2 Posted : Wednesday, November 26, 2008 3:54:26 PM(UTC)
The first thing I would do is check for continuity the spin solenoid and the spin plunger on the wig-wag (#9 on the break down diagram). Also check the wires.
Here are the break down diagrams for the Whirlpool washer Model LA7800XPW1
brbartsc
#3 Posted : Saturday, November 29, 2008 2:00:37 PM(UTC)
brbartsc
Thank you Gene. One of the spin solenoids tested bad and I have a new wig-wag on order. I feel sure my problem is solved. Thanks again! Betty
#4 Posted : Saturday, November 29, 2008 7:31:06 PM(UTC)
Guest (4)
