at123
#1 Posted : Saturday, November 29, 2008 10:18:40 AM(UTC)
at123
My GE Profile? Mod. JTP15W0D1WW started beeping (like the start button was being pressed), and finally displayed error code F0. I have reset the power (once over 24hrs), and reseated and cleaned the contacts on the ribbon cable. Now, after a power reset, the buttons will work on the key panel EXCEPT the 'start'. Do I need to replace only the ERC, or do I have to replace the key panel also, since 'start' doesn't seem to work now?
Thanks!
#2 Posted : Saturday, November 29, 2008 6:56:33 PM(UTC)
I would replace the control panel first and there is a chance you would not have to replace the ERC.
- The part number for the control panel is AP3186126
Here are the break down diagrams for the GE oven Model JTP15WD1WW
Viking gas range oven troubleshooting (Oven Repair (including Ranges and Cooktops))
by MK_ 3/3/2024 10:10:13 AM(UTC)
