Tim1400
#1 Posted : Friday, November 28, 2008 4:34:45 PM(UTC)
Tim1400
If we set the oven to 400 degrees when the oven heats up the temperature in our oven can go up to 425 degrees. We have measured the temperature with or without food and it does the same thing.
#2 Posted : Saturday, November 29, 2008 2:38:58 AM(UTC)
Here is a tech sheet with the procedure to set the temp offset
https://www.servicematters.com/d...0Sheet%20-%209756207.pdf
