mgcvitak
#1 Posted : Sunday, June 19, 2011 1:23:33 PM(UTC)
mgcvitak
Washer will not wash in hot water only. With the switch set for hot water wash, the washer starts to fill with hot water for a few seconds then the cold water valve opens and I get warm water. Temp control switch check out OK. Where does the washer sense the temperature of the washer? There is an Automatic Temp Control board in it but I cannot figure out where the temp sensor is.
sidfink43
#2 Posted : Tuesday, June 21, 2011 6:07:39 PM(UTC)
sidfink43
Try replacing the ATC board, it is likely the cause of problems like that.
