needingsomehelp
#1 Posted : Saturday, June 18, 2011 8:22:07 AM(UTC)
needingsomehelp
when we start the dishwasher it allows water in then stops after about 1 litres(10 seconds).then sits idle.(3 min) then the water is pumped out and it begins to let water in again.there are no leaks/water line in is clear and unblocked. i tried running the dishwasher with the door open and same result.i also was holding the level cap up to see if that was the problem/wasn't. water is incomming then stops then drains. elements get hot. i'm wondering if it is in the controll panel?
sidfink43
#2 Posted : Monday, June 20, 2011 5:45:18 PM(UTC)
sidfink43
You have posted on the Washing Machine forum. Please re-post on the dishwasher forum and someone should be able to help you.
Good luck.
