nubenow
#1 Posted : Friday, November 28, 2008 10:33:43 AM(UTC)
nubenow
I have an Estate washer, direct drive and needed to replace the motor coupler. Not knowing anything about washers, I lowered the gearbox by mistake before I realised it wasn't needed. I replaced the coupler with no problem, when I went to bolt the gearbox back in place, it didn't want to go all the way on the mounting dowels.
After fiddling with it it did go and I re-assembled everything. Now the drum will not turn by hand, and before I power it up and risk breaking something, I wanted to know if not be able to turn the drum is normal, or not?
AaronG
#2 Posted : Friday, November 28, 2008 10:56:40 AM(UTC)
AaronG
No a Estate washer you should not be able to turn the drum by hand.
nubenow
#3 Posted : Friday, November 28, 2008 12:24:35 PM(UTC)
nubenow
Thanks, how about being able to move the agitator? It will turn freely clockwise, but anti clockwise it is locked solid. Is this correct?
nubenow
#4 Posted : Friday, November 28, 2008 3:42:14 PM(UTC)
nubenow
I have removed the agitator, which as it happens, only moves freely the one way and not the other.
However, I think that I should still be able to rotate it both ways once it's connected, as all in essence you are doing is rotating the gearbox and the motore..........or am I wrong?
AaronG
#5 Posted : Monday, December 1, 2008 3:45:00 AM(UTC)
AaronG
no it should turn in 1 direction only there are clutches called "Dogs" that will not alow it. Also the bottem part should not turn
