kp1
#1 Posted : Friday, June 17, 2011 2:30:17 PM(UTC)
kp1
Dryer gets too hot, and stays hot. I have replaced the thermal fuse and thermistor, but it did not help.
SublimeMasterJW
#2 Posted : Friday, June 17, 2011 6:15:26 PM(UTC)
SublimeMasterJW
What you have is an air flow issue. If the heated air cannot escape the unit is going to overheat. Clean out you filter/blower housing and outside vent. Use rigid metal vent piping. If the thermistor didn't correct the problem then maybe the control is faulty.
kp1
#3 Posted : Saturday, June 18, 2011 8:11:21 AM(UTC)
kp1
Thanks-
I have good air flow coming out of the vents. What is the control, and is there a way for me to test it?
SublimeMasterJW
#4 Posted : Monday, June 20, 2011 3:42:18 PM(UTC)
SublimeMasterJW
Service manual for Duet dryer
Note use the tech sheet in your appliance for diagnostics.
Use the service manual for a reference and party on!
