hOW CAN i CONFIIRM THAT THE DRAIN PUMP IS THE PROBLEM. WHAT SYMPTONS WOULD INDICATE DRAIN PUMP FAILURE. THE UNIT GOES THROUGH THE CYCLES LIKE NORMAL BUT WILL NOT DRAIN. TRIED DOING THE "CANCEL/DRAIN ROUNTINE AND STILL WILL NOT DRAIN.
iHAVE RUN THE DISHWASER SEVERAL TIMES. I WOULD THINK IT WOULD CONTINUE TO BUILD WATER BUT DOES NOT. HOWEVER, AT THE END THE BOTTOM IS STILL FILLED WITH WATER. COULD IT BE TIMING OR PUMP??
IS THE DRAIN PUMP HARD TO REPLACE BY A DO IT YOURSELFER??
Did you just install a new garbage disposer?
