Eagle1ez
#1 Posted : Friday, November 28, 2008 7:18:13 AM(UTC)
Eagle1ez
I have a Maytag side-by-side. The freezer part is freezing fine. However, the refridgerator is not as cold asit used to be. I have turned up the thermostat to see if it would get colder, but it doesn't seem to be at this point. Is there some type of thermostat that needs to be replaced or something?
#2 Posted : Friday, November 28, 2008 7:37:00 AM(UTC)
Here is your parts breakdown
Model MZD2766GEB
Is the fan in the freezer running?
And can you feel cold air entering the fridge section from the freezer section?
If fan OK
Then check behind the covers in the freezer to see if the evaporator coils are heavily iced up. If they are then you have a defrost problem.
