Frigidaire double oven FEB27T7DCA
I've got F32 fault codes showing for both the top and bottom ovens. Also, by randomly pressing the control buttons, I've inadvertantly locked the top oven. Pressing CLEAR either for the top or bottom or both simultaneously does not clear the error. Cycling the power does not clear the error or unlock the door.
How I caused this . . . a remodelling project.
Oven was working fine. I tried to take the doors off by taking them apart. (Yes, I've since learned the proper way to do it). I succeeded in taking the bottom door apart, and have since put it back. I also removed the control panel by disconnecting the flat ribbon cable without turning off the power first. I have since reinstalled the control panel.
Again, it seems to me that everything is back the way it was yet the F32's. And the control panel is displaying reasonable information (such as the time) and is responding to most (but not all button clicks).
Happy to answer additional questions to try to figure out what to do.
Any ideas? Thanks in advance,
MITCH
(F32) Key loop is detected as an open cicuit Press Clear or Cancel key. Verify if the the keyboard is connected (P3)
Yes the keyboard flat ribbon had gotten partially unseated which caused the problem.
Thanks very much for your help.
