djensen
#1 Posted : Monday, June 13, 2011 9:51:55 AM(UTC)
djensen
The hot water on this machine will not turn off. The washer over fills and flows out the front door, flooding the laundry room.:confused:
sidfink43
#2 Posted : Wednesday, June 15, 2011 9:53:05 AM(UTC)
sidfink43
If this happens when the machine is off, it sounds like the valve is stuck in the open position. Go ahead and change out the valve assembly and that should fix your problem.
