I have a Kenmore Ultra Wash model 665 Ser.#15769000 that won't run. The cycle buttons light up, but the start button does not. Can I determine what the problem is? Thanks for any help.
The 665 tells us that the unit was made by Whirlpool but there should be about 8 digits after it which is specific model info.
Not sure if the Serial Number you show are the rest of the model number, please check it. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  The 665 tells us that the unit was made by Whirlpool but there should be about 8 digits after it which is specific model info.
Not sure if the Serial Number you show are the rest of the model number, please check it. KENMORE MOTOR 6.0 amps 0 Model 665. 15769000 60Hz 120 Volts 9 Serial FL5024041 11.5 Total amps 0 Stock no. 15769 E71195 2 Type 280-1 2
Here are your parts Replacement parts for KENMORE 66515769000 | AppliancePartsPros.comThe Sears parts site should have a parts breakdown. See the attachment for the tech sheet. Sounds like a control panel (keypad) or a control board problem. As you can see in the tech sheet a number of keys share common lines so if a certain set of keys do not work then that is where your problem is. This still does not narrow it down enough so the usual way to troubleshoot is to check the keypad with a meter, if it checks out OK then replace the control board. Still a bit of a crap shoot but your odds are better. Also you may want to try the following. Connector Cleaning / Checking Unplug the unit Open it up Remove the ribbon cable from the keypad to the control board at the control board. Clean the edge connector. If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive. Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here. Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates. Reconnect everything and give it a try. |
