5 Pages«<345
#41 Posted : 14 years ago
It is shown as #12 on the diagram.
Here are the breakdown diagrams and Replacement parts for THERMADOR PRG364GDUS GAS RANGE | AppliancePartsPros.com
nexttw
#42 Posted : 14 years ago
nexttw
Found the simmer controller at the front left bottom of the range. Will test it using the flow diagram. Will keep you posted Gene. Thanks for your help.
nexttw
#43 Posted : 14 years ago
nexttw
Hi Gene,
Good news,...
Went thru the flow chart and everything went as planned.
It turned out that it was indeed a bad solenoid. Once I replaced that, everything was operating back to normal.
Thanks again for you input and this forum! :)
#44 Posted : 14 years ago
You are welcome. I'm glad it's up and running.
5 Pages«<345
