13 Pages«<678910>»
#71 Posted : Tuesday, June 14, 2011 3:09:10 PM(UTC)
Check for 120 VAC at the inverter plug C2 between the pins 6 & 3 while the lid is closed. Post the results.
Xdriver
#72 Posted : Tuesday, June 14, 2011 3:39:32 PM(UTC)
Xdriver
Gene,
Would you mind telling me which one that is? The plugs into the board have 4(green/yellow,white/red,red/black,gray) then 2(blue,black) then 2(red,yellow) then 5(red,yellow,blue,black,purple)
Thank you
#73 Posted : Tuesday, June 14, 2011 3:56:01 PM(UTC)
This is the very left plug. It has 6 terminals and only 4 wires connected. I believe it should be White/Red and Gray wires. The plug can be disconnected from the inverter to make the test easier.
Xdriver
#74 Posted : Tuesday, June 14, 2011 4:06:31 PM(UTC)
Xdriver
Thank you Gene, the result is 120v
#75 Posted : Tuesday, June 14, 2011 7:46:13 PM(UTC)
So there is 120 volts to the inverter.
Try to reset the inverter. Unplug the washer for a few minutes. Plug it back. Open and close the lid 10 times in any 12 second period within the first 30 seconds of power-up.
If the inverter LED is still dead, replace the motor/inverter assembly.
- The motor/inverter assembly Part number: AP4536553
Xdriver
#76 Posted : Tuesday, June 14, 2011 8:08:22 PM(UTC)
Xdriver
Thank you. I tried that but opening and closing it 7 times. I'll try 10 in the morning and report back. Thank you.
Xdriver
#77 Posted : Wednesday, June 15, 2011 1:29:46 PM(UTC)
Xdriver
The reset did not work. I found a motor for $85 shipped to my door and I will hopefully be installing it this week and reporting back if this solved the problem. Is there any specific procedure for installing motor or is it as straight forward as someone with DIY ability would think. Possibly do this lid open and close? Is there an initialization for e new board/motor? Thank you.
#78 Posted : Wednesday, June 15, 2011 2:33:10 PM(UTC)
Are you sure this is the correct motor?
What is GE part number?
What is the warranty and return policy on it?
Where did you find such price? I would buy it for myself for such price.
The instructions are attached to the reply.
File Attachment(s):
The motor-inverter removal.doc (1,150kb) downloaded 28 time(s).
Xdriver
#79 Posted : Saturday, June 18, 2011 1:05:50 PM(UTC)
Xdriver
Gene,
While I am waiting for the motor, I tested between the Red and Yellow wire which is supposed to read 98Ohms and it reads 70. What would this mean? I suppose my previous 98 reading was not accurate.
Also,
Is there a way to put 120V directly to the old motor and see if it spins? Which wires would be used for this and would it mean anything in diagnosing the issue? I dont want to blow the old motor if it is still good and the only issue is with the inverter board (maybe I could use it for some other project). Thank you.
#80 Posted : Monday, June 20, 2011 5:01:22 PM(UTC)
The inverter/motor assembly receives 120 VAC, which the inverter converts to approximately 340 VDC. The inverter then uses pulse width modulation (PWM) to supply the motor with an AC varying frequency to control speed. There is no way you can apply 120 VAC directly to the motor.
The reading of 70 Ohms instead of 98 Ohms can be a sign of a bad mode shifter coil but it has nothing to do with the problem you described (no LED, dead motor).
Guest (8)
GE washer will fill and drain but no spin/agitate (Washer Repair)
by Montana_Pete 9/12/2008 6:00:02 PM(UTC)
13 Pages«<678910>»
