gwaldron
#1 Posted : Tuesday, June 14, 2011 12:01:25 PM(UTC)
gwaldron
clicking noise began this mornining. checked freezer and ice cube trays melting. Also, refrig at 55 degrees. Suspect may be compressor? How do i check if compressor is working? It is warm to the touch.
#2 Posted : Tuesday, June 14, 2011 3:24:17 PM(UTC)
Unplug the refrigerator. Remove the compressor start device (#15 on the diagram) and shake it.
If it makes a rattling sound or there are a burned spots on it, replace the start device.
- The start device Part number: AP3961332
Refrig and Freezer not Cooling (Refrigerator & Freezer Repair)
by RBazela 11/20/2011 8:17:35 AM(UTC)
Refrig and freezer not cooling (Refrigerator & Freezer Repair)
by donerite44 10/9/2009 12:08:16 PM(UTC)
