2 Pages<12
sherryLynn313
#11 Posted : Friday, June 3, 2011 9:43:08 AM(UTC)
sherryLynn313
Originally Posted by: brandels Go to Quoted Post
My lint catcher holder cracked and then a large piece broke off. The lint catcher is still in there however my clothes are getting caught on the broken piece. Is there a way to fix this withour replacing the whole machine?
HI... I have the same problem as BRANDELS (posted 10-13-2008, 09:16 PM) with a broken housing to hold the lint trap in my Spacemates dryer. see reference below Was the problem solved?
UserPostedImage lint catcher
Brand: White-Westinghouse SPACEMATES III model #sm230L
sherryLynn313
#12 Posted : Tuesday, June 14, 2011 9:29:13 AM(UTC)
sherryLynn313
in response to lint screen housing issue for White Westinghouse Spacemates. I picked up the part at Servall in Centerline, Michigan. It came in a huge box which was intimidating. After removing about 20 screws and taking off the front face of the dryer, I was able to remove the old one and install it.
sherryLynn313
#13 Posted : Tuesday, June 14, 2011 9:37:32 AM(UTC)
sherryLynn313
I had the same problem with the broken housing for my White Westinghouse Spacemates lint screen. Reading this post was really helpful in fixing my unit.
I picked up the part at Servall in Centerline, Michigan. It came in a huge box (which was intimidating) The visible part when you open the dryer door is only about 5 inches tall. What you will see when you take off the front of the dryer is that it fits over another opening which actually doubles it's height.
After removing about 20 screws and taking off the front face of the dryer, I was able to remove the old one and install it without any instructions. It's really easy to do once you take off the front.
pull out lint catcher screen not catching lint ,yet exhaust vent blowing strong... (Dryer Repair)
by zeus008 1/24/2011 5:26:45 PM(UTC)
Lint Catcher Not Working (Dryer Repair)
by fdipietro 7/11/2009 5:46:33 AM(UTC)
Black soot in dryer drum and lint catcher (Dryer Repair)
by Tdon 12/9/2008 6:41:22 AM(UTC)
2 Pages<12
