AppliancePartsPros.com
Appliance Repair Help
General Talk
Whirlpool side by side Ice maker spews water into freezer
ice maker spews water into the freezer compartment. Ice maker seems to work properly, but fill tube spews water at the back of the ice maker, it doesn't leak after shutting off or fail to shut off.
Two things come to mind. 1. Check for any ice in the fill-tube 2. Carefully pry the front cover off the ice maker. On the top right you will see a screw sideways and above it a + and- sign. This is the fill adjustment screw. :)
There was ice build up in the fill cup. Used hairdryer to melt the ice and back in business.:)
Originally Posted by: fraserm ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) There was ice build up in the fill cup. Used hairdryer to melt the ice and back in business.:) :) Guess this ole fart still has a couple of tunes left in the fiddle. :D
General Talk
