Gatito
#1 Posted : Tuesday, June 14, 2011 6:19:25 AM(UTC)
Gatito
I have a Kenmore and I believe is H3 front loader and I notice that when the machine is not in use, after a while water is inside the tub. What part do I need to change and do I need the model number?
Gatito
Joe / APP Team
#2 Posted : Tuesday, June 14, 2011 7:30:24 AM(UTC)
Joe / APP Team
Gatito
Gatito,
You will most likely need a new water inlet / fill valve assembly. The solenoid plunger is not seating correctly and allowing water to drip into the tub.
Yes, you will need to have the model number and the serial may come in handy, in order to order the correct part number.
:cool: :cool: :cool:
