teresabyrne7
#1 Posted : Saturday, June 11, 2011 8:10:52 PM(UTC)
teresabyrne7
The load size knob broke from the washing machine. (First it became stuck, I removed the knob, and tried to adjust the load size with pliers, hence broke the part that attaches to the knob.) I would like to replace this, but I can't figure our how to remove cabinet panel from the washing machine. I will appreciate any responses. Thank you
sidfink43
#2 Posted : Monday, June 13, 2011 4:57:33 PM(UTC)
sidfink43
It is not obvious, but if you will slip a thin blade under the end caps from the front you will release the clips that hold the console to the cabinet. This will get you to the switch.
teresabyrne7
#3 Posted : Tuesday, June 14, 2011 5:33:12 PM(UTC)
teresabyrne7
What type of blade do I use? Also, do I start from the outer white endcap and move in towards the center I of the machine? Or, do I start from the silver part of the cabinet and move toward the outside edges of the machine? Thank your assistance. (I tried using a long, flat screwdriver...but, no luck. Also, I was under the silver part of the cabinet.)
sidfink43
#4 Posted : Wednesday, June 15, 2011 5:35:18 AM(UTC)
sidfink43
A thin scraper will do. Just slide it under the end cap from the front. You can see an exploded view of the console if you click on the model number.
teresabyrne7
#5 Posted : Wednesday, June 15, 2011 6:47:44 PM(UTC)
teresabyrne7
Great! But, before I removed the cabinet I tried to do my usual "medium" load of laundry. The washer only filled with water. I'm wondering if I knocked something loose by trying to pry open cabinet with screwdriver. Also, after removing cabinet I noticed 2 plastic white clips laying on washer, a green wire seems to be disconnected , and my son "accidentally" dropped clips inside of holes in th holes where the endcaps were. Is this beyond my repair????
teresabyrne7
#6 Posted : Wednesday, June 15, 2011 8:41:00 PM(UTC)
teresabyrne7
I also removed the tube from the switch. The water didn't stop filling until I unplugged the washer. I blew into the tube...it seems to be fine...bubbles came out into the water. It looks like the switch is easy to replace , but now I am concerned my washer won't agitate now???? Also, how do I get water out of washer. (At least I have extra large capacity now...ha, ha, ha.)
sidfink43
#7 Posted : Thursday, June 16, 2011 3:34:32 AM(UTC)
sidfink43
Glad you got it open. See if you disconnected the lid switch and did not get it back connected.
teresabyrne7
#8 Posted : Saturday, June 18, 2011 1:01:16 PM(UTC)
teresabyrne7
Hurray!!!! It's fixed...you guys are awesome. I had to replace the lid switch also(cracked it while prying open cabinet.) Thank you, Teresa
teresabyrne7
#9 Posted : Saturday, June 18, 2011 1:09:49 PM(UTC)
teresabyrne7
Thank you! Washer is working great...also had to replace lid switch(I cracked it while prying open cabinet) You guys are awesome! Teresa
sidfink43
#10 Posted : Saturday, June 18, 2011 3:33:08 PM(UTC)
sidfink43
Well thanks, sounds like you did all the hard work. Glad you got it going and good luck. Thanks for updating us also.
