RandyMarthaKatieNutmeg
#1 Posted : Monday, June 13, 2011 11:44:46 AM(UTC)
Amana electric dryer won't heat. Have replaced heating element, belt, thermostat, heater thermostat, high limit thermostat, and thermal fuse. Dryer heated when we put dryer back together, worked once with a load of clothes; now won't heat at all. Drum turns, strong exhaust to the outside, but won't heat up. Basically rebuilt dryer--what's wrong?
#2 Posted : Wednesday, June 15, 2011 1:39:11 AM(UTC)
First check your power.
The motor requires 120 volts but the heating element needs the full 240.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Since it sounds like you tried plug and chug I am assuming you do not have a meter.
The heater circuit on this unit runs through a number of devices so finding the faulty part can be a problem.
Also do not assume that a part is OK just because it is new.
Do you have a wiring diagram?
I would suggest you purchase a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
Amana electric dryer won't heat (Dryer Repair)
by johnbharvey 7/2/2010 2:31:46 PM(UTC)
