George Madden
#1 Posted : Wednesday, November 26, 2008 1:53:27 PM(UTC)
George Madden
The dual top plate heating small or inside heating element will only heat on a very low number like 1 o2 and again on high. When the switch is place on the middle numbers the burner doesn't heat at all. I assume the problem may be the infinite switch. Could you give advise.
Thanks George
George Madden
#2 Posted : Wednesday, November 26, 2008 1:54:44 PM(UTC)
George Madden
Could you also explain the steps to replace this infinite switch.
Thanks Again
