marksapp12
#1 Posted : Wednesday, November 26, 2008 11:53:49 AM(UTC)
marksapp12
:confused: Dear Sir or Madam,
How do I replace cavity thermostat in a Kenmore Microwave (model 665.60652000)? I can see the thermostat from the front of the microwave when I remove the front grill, but it is not clear how to remove and replace the thermostat. On the sears.com (partsdirect) website it is part number 8183697 thermostat. It is part #5 in the Part results for: Air flow diagram. I know the thermostat is bad because when I override it the microwave works.Thank you.
marksapp12
#2 Posted : Wednesday, November 26, 2008 2:38:57 PM(UTC)
marksapp12
See air flow diagram below.
marksapp12 attached the following image(s):
marksapp12
#3 Posted : Wednesday, November 26, 2008 4:28:47 PM(UTC)
marksapp12
Air Flow Diagram #2. Please Note: #5 is the Theromstat that need to be replaced.
