how do i remove the front panel?
Remove the lint screen and the two screws that are under it. With a putty knife, a butter knife or a small-bladed screwdriver, push in on the plastic clips between the top and the front. As you're doing this, lift upward on the lid (one corner at a time). This will release the top, which you can allow to tilt back and let rest against the wall. You will then notice a 5/16 inch hex head screw at the top inside corner on each side of the front. After you remove them, the front will lift off retaining tabs and pull away from the cabinet. Unplug the dryer first. You may need to disconnect the wires to the door switch and light in order to pull the panel completely free of the cabinet.
