About every other day getting a small puddle of water at front of refrigerator near bottom of door. The freezer is at the top. I am quessing it has something to do with defrost drainage. Other than that refrig. is working fine. Any suggestions on how to solve this problem?
Here are your parts Replacement parts for MAYTAG MTB2656AEA REF - TOP MOUNT | AppliancePartsPros.comSounds like drain tube is plugged so that the water from the defrost cycle cannot drain into the drain pan. I believe the drain tube attaches to the drip tray (Item 4 in Section3) under he evaporator coil. Though some units drain into a funnel like part at the top of the fresh food section and then out the drain tube. I would check that the drain tube is clear. If plugged a turkey baster with warm water, an air compressor with low pressure or a wire can often be used to clear it. Also check that it is not plugged with dust etc. at the drain pan end. You might as well clean the condenser/compressor fan and the condenser coils while you are down there. If it looks like stuff is growing in the tube I would flush it with a 10% bleach solution. This should kill the stuff and let you flush it out. You may have to do this several times, let it sit for 15 minutes or so between flushes. Be careful that the drip tray does not overflow and empty the drip tral after you are done. Be sure to unplug the unit while doing this. |
THIS FORUM IS DEAD!!!!!!! |
Where is the drain tube and drain pan located on my refrigerator.
Drip tray is under the evaporator coils in the freezer (Item 4 in Section 3). Drip pan is under the unit in the compressor compartment (Item 16 in Section 1) |
