My oven thermostat need to be replaced. The button that turns the oven on is broken. I changed the knobs hoping for a cheap way out and all i got was 2 knobs lol. Can someone let me know how to replace the thermostat. thanks
ratboy915 To replace the oven thermostat is not a complicated job but first I would like to know why you believe the thermostat has to be replaced and what did you mean when you wrote: "The button that turns the oven on is broken". The best thing if you can make a picture(s) of what ever you think is bad with the thermostat and post them (or link to) together with your answers. I really want to provide the best possible help and I do not like you to waste you money. Gene.
the knob that turns my oven on must be pushed in so it can turn on the oven. It will not do that anymore. I can spin the knob in circles but it wont turn on the oven. I had someone look at it and he told me the thermostat was bad and wanted 250 dollars to repair. so after kicking him out of my house I bought a thermostat for 40 dollars. what i did yesterday was instead of replacing entire thermostat i took off the knob that turns oven on. I took off the 2 screws and the metal piece that the knob goes on and replaced it. It seemed bent for some reason. But after I replaced it the oven works fine. all knobs working well and oven heats up just like it always did.
ratboy915 Good for you! I would not do it better. Gene.
